SOHC block, DOHC head?
BigBore240
Car: 89 240sx HB KA24DE swap, over bored
Is it possible to take a SOHC KA24DE motor and frankenstien a DOHC head onto it. If so would it produce enough power to be worth the switch? I would assume so but any input or tips would be great.
All_Motor_KA
Car: 1989 240sx SE
It's possible, and I think someone did it before on this board but the big problem is the oil squirters on DOHC engines. Do a search, I think Brian explains this better.
thekage
Car: 98 Dodge Caravan
98 Dodge Intrepid
its possible... it gives you 11:1 compression... But its eaiseri just to swap the entire engine and put 89 pistons in the dohc block... still 11:1 compression.. normal upgrades, i/h/e.. basic fuel upgrades with 91+ gas, add the "hot" cams, and a light weight pulley and flywheel and you have my exact project... im shooting for about 180hp
BigBore240
I'm sure it would be a lot easier but the thing is a already had my SOHC block bored and bigger pistons installed. I'm guessing that if i swapped the motor out completely, the DOHC with the stock pistons would have a little less power. I was hoping to make up the power i lost by not getting the dual and boring that one instead. Any advice?
BigLeeRoy EngineBuilda
whats up man. where in illinois are you. are you close to clarksville, tn? me and a friend did this swap in his truck man. pm me and i can give you a run down on parts needed and everything else. he already has over a thousand miles on it. its easy as hell to do man. lemme know
