SOHC bearing sizes?
Gabes13
Car: rb20det s13
So I'm gathering up some info for a potential KAe over haul, but I've come across some confusion.
http://www.courtesyparts.com/kb_search_ ... _1420_1428
The link shows 3 different rod bearing sizes for the SOHC:
US=0.08US=0.12US=0.25
3 different rod bearing sizes for 1989-1994:
STD Grade 0STD Grade 1STD Grade 2
and 3 different rod bearing sizes for s13 DOHC:
US= 0.08 US= 0.12US= 0.25
My question is, What does the "US" and "STD Grade #" stand for? and What's the difference?
edit: I mean ROD bearing. Not Crank bearing. my bad.
Modified by pandapants at 9:12 AM 7/3/2009
maryjane
its the cut in thousands, how much your crank has been cut down, when you pull the motor apart read the back of the bearings, and itll say std/ .010 ect ect on the bearing size,
