sohc A/C problemo, turn ac on, idle falls sometimes dies.
blueballa
Car: 97 kouki
hey, first of all i want to say thanks for clicking my post,
i got a 100% stock coupe and the ac work super great. i mean insanly great. but when i turn the switch on for the ac, the clutch makes a loud engauging click and my rpm dropp from 1100 to a couple hundred. sometimes it will even die. but if i have my foot on the gas, it engauges nicly. once the compressor is engauged. it works fine, rpm is fine. its the initial engauging part thats causing the trouble. i have an extra ac laying round, & i think its the clutch, should i swap out the clutch? what do you guys think is wrong?
comatoseculture
Car: 1990 240SX coupe. Currently running on Megasquirt.
Sure sounds like the clutch is actually binding up or resisting the cranks rotation. I'd say it needs to be changed
blueballa
Car: 97 kouki
sounds good man, & thanks for the input. i just took apart my spare ac. imma switch it out next friday. ill get back to you guys & see if it works.
comatoseculture
Yeah, please update. Nothing worse then dead end posts where a solution was found and goes unknown. Good luck!
