mysterymojo8 »
https://forums.nicoclub.com/mysterymojo8-u98657.html
Sat Jun 14, 2008 11:40 am
I have the same problem with coolant leaking in the motor. I read up about possible problems and like Vegascorbin said the timing chain can wear through the timing cover. First i removed the timing cover and found that the guide had been completely worn away and the timing chain was wearing against the cover, but it had not worn through yet. Then I took of the head, and as Jovanni said there is an order to tightening the bolts as well as loosening them (start from the outside and work your way to the middle). when I got the head off, I could see visually on the gasket where the coolant had leaked into the combustion chamber. Then I did a feeler gauge test on the head and found it was too warped to be repaired. Who ever worked on the head last on my car most likely did not torque down the bolts properly and it was run too long after the head was reinstalled and before I got to the problem. A compression test is definitely a good idea.
