sohc 145psi compression time for rebuild?
Unstock240
Car: 89 240sx se
Well all four cylinders tested at 145 which shows nothing major is wrong. Just seems sort of low. Would this be a good time for a rebuild? I figure I might as well order some cp forged pistons, do a complete teardown and I plan to go sohc turbo.
Dittoz7
Car: 1997 2f0WtY SE!
Thought Normal Compersion Is ~180psi.
Unstock240
Car: 89 240sx se
i'm probably not too bad off then. i know Hondas run like 215 psi.
mixeds14
Car: 240
did u warm up the engine when u did the test or was it cold, i think that makes a difference
AZ89two4Tsx
Also, it should be at WOT while cranking. Made a big difference for me, but 145 sounds about right. Mine was 155 on all four. The main thing is that there's no big difference in the numbers. That in some ways is better than the number itself.
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
AZ89two4Tsx wrote:The main thing is that there's no big difference in the numbers. That in some ways is better than the number itself.
good point, but i think your numbers seem low. i might be thinking of dohc numbers tho, which i believe are 170-180?
AZ89two4Tsx
I think the sohc numbers are supposed to be a little lower no? Idk, my engine runs fine, no oil burning that I can see.
Dittoz7
Whoops.
~180 Are DE's
