elwesso wrote:Im not sure what advantage all this work would have over whatever consult program is available now.. Eventually you're going to build a program more robust than the hardware on the car can support!
Well I have already downloaded Microsoft Visual Studio C++ 2010 so I can learn the language and build the program.
The current Consult programs available were built on the assumption that you were using it on a 300ZX or 240ZX (V6 or I4) respectively. With the exception of Isaacs OBD Scan Tech Nissan Program that was built to do a power balance on a Nissan V8. But his transmission support part of his program assumed you had a 300ZX or 240SX.
Their is currently no LAN or complete support for Active Suspension. I want to change that As Soon As Possible (ASAP) because its been long enough we have had to rely on over priced dealers and mechanics who don't know what they are doing.
The program I wanted to build on a piece of hardware rarely found in a mass production vehicle would have possibly been to much for the Q45 to handle. But most of what I want can be done very easily such as a dyno test. Sure the dyno test may not be extremely accurate but its good enough.
The Automatic Transmission support (A/T) will see one extra sensor people can make use of.
Its hard to do divulge all the details because I don't want to see my work in someone else's program and then see them charge money for my idea's.
rabsusa wrote:hey Paul,
even with all the brains available to us here its going to be a tall order,
just to give you a magn of order, it took me 6 months to build, test
a program 1/10th of what your looking at and that was me on it full time,
are you proposing to bastardise whats currently out there or start afresh???
R
Was the program Nissan oriented?
I want to start fresh and only support ONLY the Q45 just like the 300ZX guys did with their programs. Only one person really cared about us (Isaac) but now that he has given up the OBD Scan Tech Nissan Program I think.
I am currently leaning C++ (The language this program will be built on) unless anyone has a better suggestion. But if its only me at this then I will make it easier on my self and only support 1990-1993 Q45's at first. And I may charge a small amount because if its only me at this...
I am also looking for names to call my program that will not violate any Nissan Patents.
And the good think Peter at ECU Talk did was only show the supported sensors unlike others that showed every sensor.
Please don't let this idea die like all my others. I have said this too many times.
