Z31toZ32 »
https://forums.nicoclub.com/z31toz32-u97552.html
Sun Jul 29, 2012 9:37 am
i am not an expert on this topic, but i had a similar concern when i got mine. i was told that it would have surfaced already, and that was at 55k miles, so take that for what it is worth. your rough idle could be a bunch of things, but the injector check is a good start. you can lookup how to olm the injectors on here somewhere. it is pretty easy and will tell you if one or more is out of spec or not working at all. although they will all continue to fail one after the other, depending on which one it is, you could just pop it out and replace it. long term you will probably want to replace them all because they will all eventually fail.
all the z's have a bit of lifter tick when they get older. you could try a thicker oil to quiet them down. what are you running? if it really driving you nuts, you could replace the lifters or rebuild them, but they are both decently involved processes and pretty expensive. i would just try the oil and deal with it unless you are fully restoring the car or something.
