one prob w/ the car was it had no brake pedal at all. but the res was full. so i bleed all four corners.
yes bleeder is facing up, yes i did RR, LR, RF, LF in that sequence, an yes i checked all lines for leaks. i got a good pedal after finishing. now some months later the pedal i soft again. i can hardly stop. front are grabbing slightly and rear are not at all.
i was hoping to get some input on weather i should replace my master cylinder or not, or if the rubber hoses should be replaced?
plus when i press the brake pedal it causes my engine to drop rpms and shake and almost stall out. i was wondering if i should replace the booster or not, i disconnected the vac hose and it runs better.
hope fully some one has a suggestion because my water pump on my truck is about to go so i need this car to be ready or i will be thumbing it to work
thanks and any advice is greatly appreciated
