zerepdivad »
https://forums.nicoclub.com/zerepdivad-u34747.html
Thu Feb 28, 2008 9:44 am
ok i had kind of a hard time understanding what you were trying to get out but here goes....
the plugs behind the battery when i did mine just plugged right in the dohc ones right to the sohc body.
And the ones that go to the dash are needed in order to start the car just match up these colors...
Wiring:1. Locate the body harness (under dash harness that attached to the ECU) that attached to your old harness. Cut the old connector off (the one that attached to your SOHC harness) and attach your DOHC body harness connector. Just match the colors!Yellow/Red --TachYellow/Green--SpeedometorOrange--Ignition startBlack---GroundBlue/Black---Water temp sensor
