Yellow4g63 »
https://forums.nicoclub.com/yellow4g63-u4416.html
Tue Mar 18, 2008 6:39 am
Lets get this locked in. You high Desert people have it luck because it's closer to you now. Same as last time price wise and minimum of 10 cars to make this happen. It's on a Dyno Jet with Wideband readout. Here is the Location
Apirl 12th 9am till were done with all the cars.16728 Smoke Tree StHesperia CA 92345
1-909-644-8923 is Reggies contact info if you get lost on the way out there.
"we are haveing first come first serve.when you get to the shop we will have a sign up list so check in with david or reggie and we will put you on the list.the price will be $40 for 3 pulls with afr we are looking for a min of 20 cars and NO MAX we will stay till we are done no matter what time it is.we will start the dyno at 9:00am the dyno is a dyno jet 248x 2 wheel drive.If you want your car tuned you will have to make an appointment for another day we can tune AEM efi,crome,micro tech,hal tech,and any other software you have."
Modified by Yellow4g63 at 9:27 PM 3/20/2008
Modified by Yellow4g63 at 9:28 PM 3/20/2008
