SOB need a new timing chain any suggestions?
Florida240sx
Alright I got my kit on order from IAP and received SAFC II yesterdya injectors wednesday same with Z32 MAFS. Today I went and got some seafoam.Popped my hood, and hear this ticking above my 1st cylinder/timing chain....I go ahead and run the seafoam anywayz.About an hour later my dad comes home and I ask him what he thinks it is.The noise is gone, but we start talkign and are there for about 3 minutes and it starts again.Used a stick to identify that it is the timing chain.So it's either chain is loose or the guides one of the 2.I'm going to be turboing so I need to change it, 178k on the car.Car doesn't smoke at all. Should I do anything else while I got the valve cover off?Or anyhting to watch out for or do?Thanx.Also having trouble finding what I need for it, any help is appreciated.Comp is having a war with me today can't get it to do anything correctly.
paemt6220
Car: 1997 Maxima SE 5MT - MODDED
AHHH timing chain guides! It's a DOHC right. If so here is the solution:zerothread?id=105618
Make sure you read it very cafefully, before doing anything.
Florida240sx
Just know started today...So what should I do?Remove the guides?Or remove guides and replace with new timing chain.Doesn't do it at first.Takes it a while.Engine has to be warmed up.Maybe need oil change?Has less than 2000miles though.Thinking about doing this:1.Run seafoam with oil.2.Drain oil3.Remove guides4.New oil and pray it works?Or1. Run seafoam2.Drain oil3.Replace timing chain and remove guides4.New oil and start upGoing to need a timing light just get one from autozone?
paemt6220
Check the oil pressure first. The tensioner is operated by oil pressure. If it just started, that most likely the cause. As for how to check oil pressure, you probably know more than me on that one.
As for the guides and chain. It is the upper timing chain(there are 2) making the sound. Nissan says you can remove the top guide on the upper chain. Most people remove the side guide also.(none have had problems that I know of) As far as I know(not an expert) timing chains don't need replaced unless they have actual defects, as they don't wear. Timing belts do, however, and they need to be changed every so many miles.(KA24 have no timing belts!)
If you do remove the guides, make sure the tensioner is moving freely. Instructions on how to do that are in the link.
hope that helps
Chad
Florida240sx
Guess I'll check my oil pressure, then just remove the guides and make sure the tensioners can move.
uncle_louie83
Car: 1993 Nissan 240sx Coupe
hey florida...did u ever finish up the vg30 swap into your 240? if so id like to see some pics...or atleast hear about it.
lewis
Florida240sx
No that's my future project.Goign to take me at least ayear because going to restore my convertable 1st.Might have just enough to do that but I'll be broke. If my job goes like it should I might have it being installed by x-mas or at least at the machine shop.Going to build it up and maybe put a t-88 on it.Going to be my drag machine.Right now finishing up my ka-T. Then taking vert to get a new top front seat redone and paint job.Which Time Ill be piecing together my keg kit for it.Look in Convertable forums
Florida240sx
bump. So Should I just remove guides and check tensioners?Went to daytona and orange city last night.Put 100miles on my car,when I got home it wasn't ticking.It's just now starting so what ll I need fro swap?Just new valve cover gasket?
paemt6220
Yes, Remove guides, check tenisioner. If the tenisioner doesn't move freely after cleaning with WD-40, you will have to replace it. I am not sure how to do that. Watch the video in the how-to post I linked in my first post in this thread, so you know how far the tenisioner should move. The chain hits the guides because the tenisioner isn't moving all the way out. If you remove the guides and don't fix the tenisioner, the chain will hit the valve cover(very bad). you will need the gasket and some RTV liquid gasket.
Chad
Florida240sx
where do I use thr liquid gasket at?I don't need the 2 front gasket do I ones in front of cams?Only place i saw to use RTV.Or Do I use it on the valve cover gasket as well.I saw your vid thanx.
Jookmasta
use the RTV also on the valve cover gasket........
Florida240sx
I couldn't remember..Isn't there somewhere where your not suppose to use it?Maybe it was a different product....
paemt6220
Step 7 and 8 in the how-to thread shows where to apply RTV. U can get it at any auto parts store.
Florida240sx
I got the guides out today.Still have some noise but nowhere near as bad.Going to run seafoam and then change oil.How bad will my timing be if distributor is off one tooth?Starts fine....Haven't driven...
paemt6220
I'm doing mine on Sat. Is the sound up top or down a little lower. Did you check the lower tenisiner also? You need the lower guides but the tenisiner might be gum'd up. Also, both work of of oil pressure, so if the oil pressuer is low, they may not be putting enough tension on the chain.
Chad
Florida240sx
I don't know tensioners seemed to be fine.Didn't get down to the bootom though so couldn't check the guide.I'm going to be turboing so what should I do?Anyway to check oil pressure? or just buy a gauge and mount it?Like an autometer electrical?
paemt6220
I am honestly not sure how to check oil pressure. Someone else should help from here, we are getting to the limit of my knowledge, sorry.
Chad
