May I add that my goal is not to ground pound down the street. I consider this a SQ setup with adequate headroom. All my amplifiers are older technology (class a/b) which are not nearly as efficient as the class D stuff sold today.
As of right now I have three amplifiers: Two Precision Power PC450's, and a Precision Power PC2350. The PC450's are 4 channel amplifiers producing 4x50w rms @ 4 ohms. Each of these guys have a 60 amp fuse. I have one of them bridged producing 2x200w rms @ 4 ohm for my Morel 8's. These are the midbass speakers mounted in the doors. The other PC450 is powering the the midrange which I now have mounted to the kick panels off-axis. I haven't really had any motivation to install my tweets because the midrange are handling the highs just fine, and I haven't even messed with the EQ yet!
The PC2350 produces 2x350w rms @ 4 ohms or 1400w rms mono @ 4 ohm. This BAMF is supposed to have 160amps of fusing, but I have a 150amp on it since they are easily obtainable.
I have added a temporary substage which consists of two 10's in a sealed pre-fab box. It is too cold so my fiberglassing is on hold until next spring.
My intent is what is considered a 3-way active setup with substage. 3 way meaning 3 speakers for each channel: a midbass, midrange, and tweeter. Active means that I have active crossovers. My headunit does all the processing, no passive crossovers. My current crossover settings are:
Sub stage 63hz w/ 18db slope - Lowpass (1400w)
Midbass 80-600hz w/24 and 18db slopes, respectively -Bandpass (200w x 2)
Midrange 700hz w/12db slope - Highpass (50w x 2)
+ I still have two 50w channels for when I get bored and add tweets later (speaker wire already ran)
I would like to say thank you to @swimshark. He went to the junkyard specifically to pull a set of 94+ a-pillars for me (yes the ones with the grill) and also a set of kick panels, so I was able to hack a set up and not worry about mucking up my only set. He boxed that up along with some other misc pieces and shipped it all to me in MN.
