C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Mar 03, 2004 10:18 am
Both the T3 60 and super 60 are fairly close in efficiency. The Super 60 has a slight advantage as you near redline, but both will be in the 60 percentile range by redline.
As far as turbines, A/R is only a small part of the equation. As I've said countless times before, A/R is not the size of the turbine. It's the size of the nozzle. If you really want to look at a turbo size technically, you need the compressor trim, and A/R and the turbine trim and A/R. And with T4 turbines, another factor that can be looked at is the difference between the Tangential and on-center housings. Keep in mind that turbine trim will have a lot more to do with spool-up characteristics of a turbo than the A/R alone.
As far as the size, I'm biased towards larger turbos. If I must choose from a T3 turbine, I'd get the larget trim I could, and keep the A/R a bit high as well. But that's just me. I personally wouldn't go smaller than a T4 turbine.
Keep in mind that this is the problem with choosing turbos. Everyone wants different things. There is no one "best" turbo. I'm not trying to bash anyone here. Just trying to bring the level of understanding in here up a notch. To look at a turbo more comprehensively will help you to make a better choice and promote more technical discussions.
To elaborate, aleph1, instead of asking what the best street set-up is, perhaps ask, what kind of spool-up and boost levels does someone have with a Stage II T3 Turbine with .63 A/R with x compressor wheel. Asking for fact instead of opinion will help you to decide what is best for you.
Again, this is not a bashing post and I'm not picking on you aleph1, I only used your example since I could see it as I typed this. I'd love for more of you to just be able to look at things a little bit more critically and make your choices based on technical data rather than relying solely on someone elses's 'opinion'. An opinion is too subjective and for most of us, a turbo is a substantial investment. I'd hate to see a person make a bad choice for themselves because they relied on opinion instead of something more concrete...
