Now for some technical mumbo jumbo that will be helpful
When buying new tires for the 350Z, make sure you get at least Z rated tires, no this doesn't mean that the tires were engineered for the Z.
Speed Ratings and info taken from
http://www.tirerack.comL 75 mph 120 km/h Off-Road & Light Truck TiresM 81 mph 130 km/h N 87 mph 140km/h Temporary Spare TiresP 93 mph 150 km/h Q 99 mph 160 km/h Studless & Studdable Winter TiresR 106 mph 170 km/h H.D. Light Truck TiresS 112 mph 180 km/h Family Sedans & VansT 118 mph 190 km/h Family Sedans & VansU 124 mph 200 km/h H 130 mph 210 km/h Sport Sedans & CoupesV 149 mph 240 km/h Sport Sedans, Coupes & Sports CarsZ 149+mph 240+km/h Sport Sedans, Coupes & Sports CarsW 168 mph 270 km/h Exotic Sports CarsY 186 mph 300 km/h Exotic Sports Cars
Uniform Tire Quality Grade (UTQG) Standards A.K.A. Treadwear Grade, Traction Grade, Temperature Grade
i.e. 300AA A
The number 300 represents treadwear rating as defined by U.S. Department of Transportation(DOT)
Toyo Proxes 4 Treadwear Rating is 300
Bridgestone Potenza RE050A Rating is 140
The higher the Number, the more they will last!
The Following letters AA represent the Traction grade as defined by U.S. (DOT)
Traction Asphalt ConcreteGrades g force g force
AA Above 0.54 0.41A Above 0.47 0.35B Above 0.38 0.26C Less Than 0.38 0.26
AA is the highest rating right now
And lastly, Temperature Grade, The UTQG Temperature Grade indicates the extent to which heat is generated/ or dissipated by a tire. If the tire is unable to dissipate the heat effectively or if the tire is unable to resist the destructive effects of heat buildup, its ability to run at high speeds is reduced. The grade is established by measuring a loaded tire's ability to operate at high speeds without failure by running an inflated test tire against a large diameter high-speed laboratory test wheel.
Temperature Speeds in MPHGrades A Over 115B Between 100 to 115C Between 85 to 100
Numbers and charts were taken from
look here and here
I'm tired of typing now, I hope this is helpful for someone.
Have a good one!
Modified by albert_ey at 12:05 PM 7/27/2009
