I have an ASP U/D pulley, it seems to help you alittle up top and smooths things out a bit. I installed it in conjunction with an e-fan conversion, and AC removal. It definately helps but its more of a complementary upgrade, only get it if your lightening other areas of your engine. Dont just drop it in and expect that much of a difference. Best combo would be, e-fan conversion, U/D pulley, AC removal, and lightened flywheel. Im working towards that point but flywheel is pricey and will have to wait.
Only problem I have had is I need to bump up my idle. At night with all the lights on the idle dips maybe 150 rpm. Your underdriving your alt and PS so understand these items will be putting out low power at idle. At any rpm over 1000 the alt will charge normally but its sketchy below 800 with some draw on the system. Only difference between me and other peoples setups is the two e-fans wired up which increases the drag on the alt more.
Do not buy this if you have big stereo equipment in your car, sitting at an intersection your headlights will probably dim to the intensity of flashlights
