C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Tue Jul 22, 2003 2:32 am
I agree that recirculating does set a new set of issues, but in actuality it should be somewhat negligible in terms of heat. Recirculating hot air will increase heat by the efficiency of the boost and there for be about 20-30% hotter. If it continues to recirculate the same air, it would keep heating itself up. Of course some of it will be diluted by incoming fresh air. But regardless, the hot air would eventually have to go through the intercooler.
If mounted on the cold side, the intercooler will have cooled the air down, but have absorbed some heat in the process. Either way, ultimately the same heat (energy) would have to be absorbed by the intercooler.
As far as venting hot air into the engine, it will be diluted by the air that is already there. I'd suspect as long as the BOV is not aimed right into the filter, a very small percentage of it would be taken in by the motor. Some careful locating of the filter and BOV and perhaps some trick piping or baffles may reduce or even eliminate this effect.
If I were desiging a race turbo motor, it would incorporate a open BOV though.
I understand what you mean about the TB. I picked up my June issue of SCC and in the Compressor Bypass test they did, they mention the TB side is better, but offer no technical reasong as to why. So it's a possibility the TB side may be better, but I still speculate that the higher pressure of the hot side may pose more surge. If a BOV releases based on pressure differential between the vacuum signal and the pipe pressure, I would think you would want to release from the point where pressure builds the fastest. But again, this is where technical data would be useful...
As far as the I/C, I highly doubt an engineer was thinking to use a BOV to keep a I/C from blowing up. If an I/C does fail, it was either poorly made or just seeing pressure beyond it's design. The BOV is really a fix for the compressor surge problems. Turbos got a bad rap with early turbo motors because of frequent turbo failures.When factories started using DV's(BOV's) in their turbo motors, reliability went way up.
