so what will it take to get an s14 diff into my s13?
egan
what will i need besides the differential. do i need new output shafts or a different differential cover gasket, or .......thanks
or is it better to just get the whole pumpkin??
edit: i just need the new rear cover right?
rco8786
If you get the whole pumpkin it is completely bolt on except you will have to buy 2 new bolts from a hardware store b/c the ones that mount the S13 are smaller than the ones needed for the S14. If you get just the dif then your s13 pumpkin should work/fit but don't quote me on that.
