GQ Jay wrote:1.) thanks for the replies. i'm now leaning toward the 245/45, but the 235/45 is not 'short' at 26.3 compared to factory 215/65/15 at 26.0-26.1 2.) why would you two assume i'm skimping on load index? 235/45/18 come in 98w (csc2's and ecsta spt)ps2's in 245/40 come in 97y (if you ask for it).factory was 95v, so that is my minimum criterion.
3.) i'm liking the zero nero in 245/45 with a 96w--but $1000 out the door--sheesh.
4.) btw--i'm not finding ps2 in 245/45/18
1.) Either should work, but I would still do the 245/45
2.) There are definitely benefits in performance and wear by maximizing the load index. REad Q45tech's posts on slip angles. Also on Kumhos. Don't know what CSC are.
3.) Zero Nero is good, but look at the top Goodyears that z likes. For a good 18" tire, you will have to pay.
4.) PS2 is 255/40-18 99Y, about $265 ea. from Costco, a little more from TR. AZhitman had the same size Rosso Asymmetrico on 18x8, but I think an inch in from vertical on that short a profile is not optimal for sidewall flex and bead seating angle.
Don't go cheap, unless you wnat to spend twice when the tire wears out prematurely or fails you in a critiacal situation, or is just a plain POS while driving and to balance.
Modified by maxnix at 6:34 AM 5/19/2006
