DriftingisLame »
https://forums.nicoclub.com/driftingislame-u25409.html
Wed Jan 14, 2009 10:44 am
Apart from the oil issue. The bottom end of an RB20 is extremely well balanced, probably due to the very small stroke. The super burly rods, and tiny pistons they have to carry, and well balanced crank are definately not an issue. In fact I've heard of 9500 rpm with standard bottom ends, I myself have turned my motor to 8200 with a stock motor (plus bigger cams and bigger turbo). I think the only issues you will have are making power at a higher rpm, and the hydraulic lifters.
I dont see a problem with 8500 provided you have the cams and turbo to see power at that rpm, and provided your oil pump drive doesnt round off. Any higher than that and you could spend thousands on bigger cams, solid lifters, aftermarket oil pump, with restrictors, return lines from the head, modified oil pump drive, etc. The list goes on, and the money will really be flying out of your wallet if you want to go much higher than that, lol.
