DarkBlueSr240 wrote:Wait where did you see this at? cause I saw like 5 or 6 thousand dollars.
What you are looking at is called a "Stroker Kit". Changing the stroke of an engine is very different from boring it out.
(Price taken from Phase2)
http://www.phase2motortrend.comStroke Kit $4,495.00 HKS 2.2 Stroke Kit
Bore Kit $499.95 CP Pistons 87mm $499.95 HKS Sleeve $125.00 ARP Headstud Kit $210.00 APEX'i Headgasket $369.00 Eagle Rods (not required, but recommended) $200.00 PE F1 Rod Bearings $280.00 PE F1 Crank Bearings------------------------------------------------------Total $2183.90
This is just to give you an idea. Then remember you need to find a good shop to do your work. Don't cheap out on labor, you'll pay for it later.
First you need to set a goal on the level of performance you want to achieve.(mild, wild, all out) The higher you set your goal, the more you will spend.
