slownslurious »
https://forums.nicoclub.com/slownslurious-u29303.html
Sat Jan 20, 2007 10:51 am
I could do them for $600 each or so, but at that price I wouldn't be making any money selling them and it wouldn't be worth the effor to make the mold unless I could sell at least a dozen or so of them.
The real problems that I see with making a hardtop for the vert:1) rear window. A plastic rear window would be much lighter and is what many miata hardtops use. It could be curved to improve the massive blindspot verts have with the top up. This would have to be molded. I don't have the equipment to do that. Outsourcing would be expensive. Also, plastic scratches a lot easier than glass. What could be much cheaper/easier is to identify a vehicle with rear glass that is capable of working and that is common enough in the junkyard to secure a second hand supply. For thos in the snowbelt this option could even provide a power defroster in the rear. Pimp. It would also make the top a lot heavier though, and probably limit the top to a smaller squarish rear window approximately the same size as the rear one. one option I have eyed in several junkyards is the RX7 convertibles. They used a folding top with a hard roof section over the occupants, and the rear window is heated glass approximately the same size and shape as the vert rear window. Only thing is, the yards here want at least $100 per for the rear glass, and I have a feeling rx7 verts are rare enough that I would only be able to get a handful of the rear glass units.
2) fitment. How would the top fit? Would it fit OVER the stock top (with the stock top folded down). This would be less than ideal for a few reasons (stock top gets moldy etc when folded down, hard top would have to be especially bulky to flare out over the folded top, and the folded top eats up extra trunk space).Would people want a hardtop if they had to remove their soft top to install it? I think this would limit its appeal....Furthermore, If I was selling things for the vert I would also want to produce a hard boot cover and a hard tonneau cover. The hardtop could be much smaller and more lightweight if it was designed to be used in conjunction with the hard tonneau cover, but would those of you with children etc be willing to purchase it if it didn't allow the use of the rear seats while isntalled?
3) attachment. No where on the stock car is there any convenient fitting to mount the top to. I dont know what to do about this except include acceptable hardware with the hardtop designed for permanent attachment. Would people be willing to accept this solution?
What about attaching it to the windshield frame at the front and sealing it around the doors? For the top of the window seals you could use regular weather stripping, but because of the stock hook system in the front the easiest solution would be to use a 240sx convertible header bar as the front of the hard top. There probably just aren't enough header bars in the junkyards to make this option available to everyone that might want one, and making a custom front header bar would increase the cost.
4) costwould people really want one if I completed it and it ended up costing $600? $800? $1000?I really won't know how much the parts and labor will run until I do the first one, so i couldn't set a price. I probably wouldn't want to start a mold until I had pre orders but I'm not sure what the price would be.
5)compatibility with aftermarket upgradesThis is a huge area of concern for me. My car, which would presumably be the model I would use to design the top, has no rear seat, coupe doors, and I am planning on removing the stock top. There is no way I could assure that the hard top would fit other cars without having other models to test fit during the design process. In addition, a roll bar that clears the stock soft top would probably not clear a small top designed to work with a tonneau cover. A full size hard top that allowed rear seat access MIGHT work with some roll bars but probably not all.
As you can see, these are many important issues that hinder the development of such a product. There are far fewer hard tops for 2+2 convertibles than for 2 seaters because of these reasons. The easiest, lightest, cheapest, and most convenient top would be a hard tonneau and a small "2 seater" top that covers the 2 front seats.
