to NICO!
For that kind of $$ you can't go wrong. I'd start with changing all of your fluids... Suspension is a pretty big undertaking, but everything is pretty much available.
The timing chain guides may be an issue on your Q. 1994 was the first year with the metal backed ones. We have some reports of the 1993 having the updated guides, but there's no actual VIN cutoff or date to go by. You'll want to search the forum for "timing chain guides" and educate yourself on that.
Fuel pumps and their control module are another common failure item. If you hear something like a hive of bees behind your back seat - especially at idle with the tank under 1/4, it's time for a pump.
Others will add more, but that's the quick run-down.
Heath
