ganma_ca »
https://forums.nicoclub.com/ganma-ca-u122380.html
Sun May 31, 2009 4:24 pm
Continues lol...... My last post I had lost the coolant via the hose under the intake manifold. I have replaced the hose. Tried it, over heated. So I tried a little trick by placing my heat on 4 and all the way up then ran fine for a bit and overheated, my guessing was the thermostat. So I replaced the thermostat. Sweet everything worked fine for a little bit. So I added an electric fan, keeps it pretty much cool for a little bit can drive around for awhile and then the over heating again.... I'm guessing maybe I need a larger radiator???? I am using the stock kae radiator which blows nutz because it;s a 1 core and the core is like a cm thick... Bleh and old as s***e but it worked for the longest time before for some reason? I checked for coolant in the oil and no dice so the hg should still be good. Any idears? I'm stumped. Oh an on another note, the electric fan I added stays on all the time, and when it does start to overheat I crank the heat back to 4 and all the way up and the temp starts to drop again but it takes a bit.... P.S. If indeed I do need a new rad. anyone have any awesomeness for cheap like a 3/4core???? Thanks
