destroyyourmind »
https://forums.nicoclub.com/destroyyourmind-u81700.html
Fri May 02, 2008 4:30 pm
so I start to have this problem where it doesn't wanna start sometimes running really rich due to a broken o2 sensor. wouldn't start at all a little bit ago after I drove it on and off all day. Tried for thirty minutes, pulled the plugs all of them were fouled. Switched out with new plugs and still does the same thing just turns over checked all the fuses, replaced distributor cap, rotor, and button not even 2 months ago. Wires aren't the greatest but they haven't failed me yet since I'm tight on money. Got a **** load of people to push it and popped the clutch and it finally started and runs great minus the fact it won't start after daily driving on and off. A lot of times it seems to start to quick, it will start as soon as the key is turned and sputter then stay on. Then sometimes it will turn on and the idle will go up then drop down and the car will die. Lately its seems my idle is sketchy going up to 1500 at random times. PLEASE ANY HELP IS GREATLY APPRECIATED.
EDIT. replacing coil tomorrow, possible culprit.
update took longer than it usually does to start backfires a whole lot more getting fuel, compression was 175 on all four cylinders
Modified by destroyyourmind at 11:16 AM 5/3/2008
