teddy wrote:He's right. Standard is 171psi according to the FSM, and the minimum is 142. You can have up to a 14psi variance between cylinders. The compression is starting to get low, but you could probably hold out for a little while if you wanted.
my variance between all 4 cyclinders is 4psi from the highest to the lowest.How much power loss on my compression would there be ruffly from perfect compression?
I have a T28RS waiting to be installed, and i'm boostin 10psi on my T25 and the T28 is set to boost at 12psi and i have a boost controler too, was planing to boost at 14.5psi
One other question will CA18DE rings fit DET pistons?
Modified by XTCshri2222 at 11:50 PM 3/22/2006
