Ni2s4s0aSnX »
https://forums.nicoclub.com/ni2s4s0asnx-u27980.html
Tue Jan 03, 2006 5:19 am
Ok, lets see if I can answer some of these for you.First Question: Might be a fuse, check that, and if that isn't the problem, I couldn't tell you what it is.
Second Question: Also might be a fuse. Third Question within the Second Question: The brake lights should come on when you press on the brake.
Third Question: The speedometer problem could be a loose speedo cable. I don't know about the tach problem though.
Fourth Question: No, there isn't a way to remove the gauge cluster without taking apart pretty much the entire dash, but it isn't really as difficult as you would think, you just need to have the time to do it.
