sivart33 »
https://forums.nicoclub.com/sivart33-u25143.html
Sat Dec 13, 2008 1:52 pm
sr has been having some problems and the cat was glowing red one day so today i cleaned out a cat to see if that was the problem, and well nothing happened. still have a shaking issue and it does not want to rev like normal. did a little diagnosis and the only thing i could find was that the vacuum line to the bov/egr valve thing(green stripe on it) it had no vacuum to it. is it only a boost line?
then when i disconnected the other vacuum line it ran the same, and when i took the valve cover cap off nothing changed. i know its suppose to idle down but nothing happens. prity soon its going to a shop if i can't figure it out but i would imagine it is a vacuum error but the vacuum lines are put in place like they are suppose to be. no leeks it seems.
i know that was a novel, but no idea what is wrong i am going to search more on the internet. but no idea. any help would be greatly appreciated.
i could blow into the bov vacuum line and i could hear air leaking i pinched it all the way to the intake manifold and it seemed fine but i could hear air passing through it. is that normal?
it is idling around 1k rpm. i am using the stock vac line set up, with the big nipple blocked off due to i am not using a canister. i am using a blitz bov and the stock side mount is just hanging out down there. i should plug its vac line but i did not think that would matter at all, but now that i think about it, its kinda simple.
i got new plugs in it i am getting fuel for sure. i still have to disconnect the vac line from the fpr to see if the rpms go up to see if it is a bad fpr. the sr seems totally fine but the shaking and now not revving correctly. i am totaly lost on everything with this now.
<grammar messed up cause this was a person message that i copied and pasted with some additional info>
