the first one burnt out so that it wouldnt even kick the fans, this one burnt out so they are on all the time now........OKRB20DET wrote:if ur fan stays on forever...how can ur engine over heat?
Probably spec's at 7.5A but most likely a lot more. Also that's running current. Startup current draw is much more than that, and is probably the cause of your problems.Carl H wrote:well with the fans i have now they both draw 7.5 amps apiece.the relay is rated 40/50a so it should handle it no problem.the switch is also designed to accomodate 2 electric fans, so im really not sure whats going on.
