Hotter I believe. Florida baby.Poyzinous wrote:Unless they are douchbags, a z-tube wont affect the warranty. and it will give you a 5 pretty prancing pony power progression, in laymans terms, 5 hp increase. Aside from that, it looks nice. I really like white. It fits well on every infiniti but the FX. Is the satellite radio installed? the antenna is there. Get some wheel locks too. 999H1-A7003. $40. Your tires look 3psi overinflated. 70* outside? Set them to 37psi. Anyway, Congrats
Joey666Crack wrote:Exterior wise I was thinkingCarbon hood and trunk and blacked out tail lights for now
Yea I was just posting and I noticed. I thought "cool!" and took a pic. Now that you mention it, its much simpler just to print scr...TeflonG35 wrote:Hey poyz. You should have did prt scrn instead of taking a pic for your sig.
No. Only aftermarket parts that cause the problem are not covered. Aftermarket exhausts are common. However, if you have to have your trans pulled, the dealer will charge you $150 to remove the exhaust because it's not OEM.Joey666Crack wrote:Do you think true dual would void the warranty?
