Spark plugs smell like gas. I can hear the fpr regulating the pressure with the car in the "on" position.rico05 wrote:So you are sure you are getting fuel Chris?
I am going to try and get Sean to drive all the way out here again with his 240 so I can troubleshoot. Seeing as he has known good working parts and pretty much the only person I know with a CA within 50 miles. Lastly, I have an eprom programmer on the way, although I am going to use the programmer here at school to attempt to burn a new chip probably tomorrow.float_6969 wrote:I don't think it would run very well with a maxima MAFS and 450's on the stock ECU.
Get stock stuff on there if you can, and try it, or get Rafi to burn you a chip.
LOL, no. I lined up the notch I am going to do a little more investigation today to see if I can come up with anything. The O2 sensor isn't hooked up yet either, but again, that should have nothing to do with it starting and idling.float_6969 wrote:Not to point out the blatently obvious, but you didn't put the chip in backwards did you?
I'm working on it DOOD! I've been waiting a YEAR to get this damn thing running! My patience should have paid off by now!float_6969 wrote:w00t! Get this bizitch runnin meng!
Be patient young grasshopper. You need to run your engine with the stock junk 1st and then graduate.c-rad wrote:
I would if I had it. People sell the damn stock injectors for almost twice as much as I paid for my 450s. And I got the Maxima MAF for like $17 at the junkyard.boost_boy wrote:Be patient young grasshopper. You need to run your engine with the stock junk 1st and then graduate.
Dee
With the stock EPROM and no SAFC?iliketocrash wrote:if it helps at all, my car runs and idles well with dsm 450's in it and stock maf. She's a little rich but nothing too bad. definitely no problems starting. fires right up.
You know, my friend suggested that last night and I am going to try that today. He said looses the cas bolts and have someone slowly turn the cas towards the advance direction while cranking it. I am going to try that today.teddy wrote:Mine did the same thing as yours c-rad. I spent so much time and effort into prepping the motor, buying all the parts and getting it ready, and the night of trying to fire it up, it would only turn over and spits out mini fireballs(which is kind of like a mini fireworks show). Turns out that when I had taken out my CAS to remove the timing covers, my timing got out of whack somehow. Fixed the timing, and put some fresh gas in and it fired right up.
Well, since you went through the hell of putting in your 450s, you're going to have to get the goodes to make this happen correctly. Be sure and check the the key on the CAS as well. Sometimes you can be a victim of the exhaust cam key breaking off or worse, the crank angle sensor's tip breaking off.c-rad wrote:
CAS is good. Just checked it. I am thinking regardless of them being 450s, the engine SHOULD start and idle, right?boost_boy wrote:Well, since you went through the hell of putting in your 450s, you're going to have to get the goodes to make this happen correctly. Be sure and check the the key on the CAS as well. Sometimes you can be a victim of the exhaust cam key breaking off or worse, the crank angle sensor's tip breaking off.
Dee
c-rad wrote:It runs!!!!!!
...barely. If I crank it long enough it eventually starts running but I need to feather the throttle to keep it running. At least thats a good sign. I think with the correct eprom in there it will stay running. I think the injectors might have been a little gummed up and it took constant cranking to get some good clean 93 through them. I am going to try and burn a new chip at school today so we'll see what happens. At least I am happy that I know I can get it to run, as crappy as it does.
DITTO!tyrannix wrote:+1
(yeah, you beat me, im still doing wiring.. there needs to be more hours in a day... i distinctly remember having more free/car time when i was single)
