I'd just go ahead and do the whole timing kit you might as well. Are you going to be doing it while it's in the car? I did mine in teh car and it honestly wasn't all that bad once you get all the crap out of the way. It's just time consuming. took me a few hours, to do the chains guides and tensioners. Although when i did my other motor out of the car it was a Lot easier. It is a pain to do though i had to drop the oil pan so i could get the lower timing cover out because of the oil pickup tube. good luck with it.SketchyRollin564 wrote:im hearing some annoying *** noises that are coming from the timing chain rattling, or the guides or whatever. I read the upper guide isnt required and you can take that out and itl fix it. but my engine just rolled over to 169k, so im guessing its gonna be a good time to replace the timing chain itself?
I plan on going KA-T in the future, so id be doing it anyways. But since im doing this, is it just a good idea to do the whooooole timing kit all at once?
i dont know much about this stuff, im still learning, but i figured replacing the timing chain once im down there will be easy, since im already taking out the guide, which apparently is said to be a 3 hour job?
yeah i'm sure you'll be fine regardless, 240's are pretty easy to work on. plan on spending at least a day on it maybe 2 if you haven't really worked on engines that much previously. if you have any questions i'm sure there's plenty here that will help.SketchyRollin564 wrote:Yeah i have no experience working on engines and crap, so idk how hard its gonna be, but i plan on doing it in the car if i can, and i guess spending a whole day on it
on a random side note, did a compression test on my car today, and i have 180 on all 4, so thats good
HAHA Like I said my two best friend are master techs w/ air tools. So taking off belts and engine mounts and oilpans is nothing to them. It was inside the engine that was foreign to them. Me by myself , yeah 6-7 hours. Me getting in the way of now KA24DE specialists w/ air 3-3.5 hours. LOL480sx wrote:3.5 would be a dream too.. Lol
i just loosened the motor mounts and jacked up the motor a bit and just had to drop the sway bar and that's it to get my oil pan out.D-UNIT wrote:yep he is right. to take the oil pan off in the car you need to lower the crossmember . to do that you need to loosen the engine mounts and remove the steering shaft.
hint: you need to take off the oilpan to take the lower front cover off ( there are two bolts going up from oilpan holding the cover on) took us 1 hour to figure that one out , (WTF... Nissan silicone seal is super strong -- doh!)
Hint #2 : lining up the multi colored timing links . There are five , two on the lower chain and three on the upper chain. once you line up the links and spin the crank the marks will never line up again. The toyota and chevy guy flipped their lids( because on their engines u spin the crank once and the marks go 180 off. you spin it again and they line back up. The KA doesn't. EVER. It took us five times of taking off all the chains and sprokets (and finger crossing) to figure that one out. hope that helps. It would have helped US go faster.
Just change everything one time. Moral of story : Engine started on the first crack and purred like a kitten. All you could hear was the ticking injectors. Sweet! I'd do it again in a heartbeat. To hear a KA run so smooth was awesome!
Might as well do the water pump and thremostat while you are in there.
