sdwyzs14 wrote:well thats not just a removal affair, but sortof..on the ka the water pump and ps pump are on the same belt, if you completely remove the water pump how can you ensure tension on the water pump pully, well were geniouses over here so we just pulled the internals out of the water pump. with the removal of the four bolts on the back you can pull the cover off and remove all the pump stuff then put the cover back on...i left all the lines in place and fluid in the system. this is purely experimental but should work.
you should note that pulling all the internals of the water pump will cause your car to overheat.
did you mean to say that you pulled the internals of the power steering pump? I'm sure you could find a belt small enough for just the crank and water pump by themselvs.
