So I was at the Track this Weekend......
Nskylinerb-25
Car: 89 240sx
So I went to the track w/ my 240sx RB20DET to see how my car ran and what was my best time and I found a little problem w/ it. It seems that when I take off it pick up normal until about 3000-4000 RPMS and then looses power completely and picks right up, all this is happening in first gear then after that the car will hall *** down the track don't know what could be causing the problem any ideas. Oh by the way my best time was a 14.1@100mph at 9psi.
Please help me!!!!!
Sil240
Car: Nissan S13 "The One Cam Wonder"
Did you check to make sure all of your pipes are secure?? What boost controller are you running?Maybe you need to adjust it.Do you have a wide band or a A/F gauge?Is boost steady as you go down the track??
Nskylinerb-25
Car: 89 240sx
Yes all my pipes are secureI have a MBC Turbo XS don't know how good that brand isNo Wide band or A/F gauge do I need one.and yes boost is steady all the way down the track.
mello88
Car: s13
Might want to check your plugs, ignitor or coil packs.
