One Crazy Max »
https://forums.nicoclub.com/one-crazy-max-u77654.html
Tue Jun 24, 2008 10:50 am
for everyones information, i was at work, and was not able to post anything about it, so for those people that want to be idiots about the whole credit thing...grow up. i only wanted to know if anyone did it yet, and if i was the first.
and just so you know it took a while to figure out how to actually go about doing it, because its not as easily laid out like it was on my 4th gen maxima, i had to take time to actually test about 10 different wires before i found the correct one, and i still didnt find the relay for the foglights, so i ended up cutting out the fuse for the relay and hardwiring each foglight to its corresponding parking light.
by the way, i know how this forum works, very similar to my local forum that i am on. and i never said that i wasnt going to tell you guys how to do it, i said that i was going to tell you later, which is what i intend on doing. i should have a write-up probably by tonight, and at the latest, saturday night.
btw, the only problem that you will have the way i did it is that the switch for the foglights is now inoperable, meaning it doesnt control the foglights. the way i did it is when the parking lights come on, the foglights turn on and they dont rely on the headlights to be on for them to come on. so that means that even when the high beams are on the foglights are still on. that is the only problem that i have come across. to change the outcome of that, you would have to find the relay for the foglights and wire the power from the parking lights into the relay(s) for the foglights, but i dont know where the relay(s) are, so i wasnt able to do so.
i will upload some pictures later on this evening.
