RB280SX wrote:Well, after coming home yesturday from school I frantically did some work on my car. I noted the problems and now the only thing that I can do is wait for someone to help me out .
1. Car won't rev past 3.5k (begins to sputter around that rpm).2. Car won't start again if you rev to 3.5k unless you give it a nights rest.3. Idle won't go down, even though I screwed the IACV as far as it will go (clockwise).4. Car runs richer than Bill Gates, causing it to puff black smoke when giving it gas.5. Radiator fluid is leaking from somewhere (near top of the radiator, it is spilling onto the coresupport), however, the radiator itself is not wet?
That's it for now . Please help. Thanks.
#1 your MAF is bad or the wiring is wrong.#3 check the Throttle body to make sure that it's not missing a screw in the butterfly (Had that problem with my SR20VE), Could be that your missing a vacume hose for the Idle air or something.#4 prob cause of the maf problem and Intercooler pipe leaking could also cause #1.#5 check your house clamp? might have dug deep into the house and cut it.
Build a psi tester and test your system to check to see if your intercooler piping has any leaks in it. Will save you so much time, and get a multi meter and check your maf wires to see if there right. 12v on one and 0-5v on one. 0-5v is going to be your signal wire, 12V is going to be the power and the others are grounds. Start slow and take your time and it will come to you. Could be a bad ECU too.
