TheOne »
https://forums.nicoclub.com/theone-u18820.html
Fri Dec 28, 2007 9:14 am
i've been through maybe 4 engines(+ a head rebuild due to bad cam timing, which looks like what happened to yours, maybe chain got loose or something?)
i guess its cheaper around here to get another dohc than over there.
as far as dohc>sohc swap, you'd probably need power steering lines too as the sohc pump is on the other side i believe, and the wiring harness which you'd need the sohc harness + maybe the cluster harness.
