I have this problem all the time lolllllPhyrx wrote:It seems too long VERY TIGHT fit
i just swapped guts out in my differential. for a HLSD pretty easy as long as you keep stuff in order. you do needa vise tough. to be able ot torque everything down.Phyrx wrote:Anyone?
I cant find any info on swapping the diff guts out. Is it possible?
Why do I have the feeling you didn't properly reshim the diff and just stuck it in there with the original shims.idahotuner wrote:i just swapped guts out in my differential. for a HLSD pretty easy as long as you keep stuff in order. you do needa vise tough. to be able ot torque everything down.
because that is how i did it. but it was a perfect fit. lol maybe justa little tight but it slid together good. i haven driven the car yet. but should be fine. diderson did the same thing.Hijacker wrote:
Trust us. If I were you (and goes for Didderson too) I would bring it to a qualified shop that does diff installs and have them re-shim it. Not only does it make for a quieter running diff, but it reduces wear and tear, and possible breakage do to the presence of improper tolerances/excessive (or lack of) play. A diff that locks down while driving at speed, is also no fun. Again, my .02idahotuner wrote: because that is how i did it. but it was a perfect fit. lol maybe justa little tight but it slid together good. i haven driven the car yet. but should be fine. diderson did the same thing.
The only sides of that fence are the ones that do it right and the ones that do it wrong. Poor backlash adjustment will result in premature ring gear failure. And the only way to confirm backlash adjustment is if you took the time to check tooth engagement with a solution like prussian blue and played around with the shimming. I've put 3 differentials together so far and none of them have chattered or broke. I was also taught to do it properly by a man who has been working on cars longer than most of us have been alive. I've been lucky that I haven't had to reshim the pinion gear yet.idahotuner wrote:^ THANKS. but i would gaurantee that my differential is going to work perfectly. as far as shimming there is alot of people on both sides of the fence.
