So I need to install a boost gauge...
chickentendah
Car: SR20DET Hatch
And I did a search and found little information.
Where is the "proper" place to run the vacuum line from the boost gauge? I did a search and some people here mentioned that they tapped off the "FPR line". Can someone clarify this?
Today to test the boost gauge, I tee'd off the line that runs from the wastegate-to-coldpipe nipple, and my redtop reported 10 pounds of boost. Is this setup correct too?
Your help is greatly appreciated!
robbbby
I run mine off the intake manifold.
f150intally
I can confirm that you need to tee off of the fpr line. That is how it should be hooked up.
quiksilvia
Car: 95 s14 se
10 psi is not stock psi. go to http://www.srswap.com under swap faq and then vac lines itll tell u with pics what to do
stumpz
mine reads 6psi off of the vac line that runs right into the valve cover. it's on the passenger side of the valve cover closest to the firewall..hope this helpz
chickentendah
Car: SR20DET Hatch
Thanks guys.
I'm getting mixed opinions on this from different threads and forums.
I'm posting a new thread since I'm going to change the subject a bit...
f150intally
FPR, FPR, FPR... tee off of this dude!
BuudWeizErr
http://www.sillbeer.com/vaccum.php
that is the correct way.
SpeedRacer1
Car: 1990 240SX, G35
My blitz instructions said fuel pressure regulator. This is the most accurate reading. Wastegate, crank ventilation and other holes are reading different pressures.
runyun
rgr that... T it off the fpr vacuum line.piece of cake
chickentendah
Car: SR20DET Hatch
Affirmative. The boost gauge now reads as I have originally expected it to read.
SideWays Silvia
Car: Drifting, Tuning
T it off of the fuel pressure regulator line
