gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Tue May 22, 2007 4:22 pm
wut in the hell.....From the beginning.Set up your timing marks to TDC. Crank and cams (dont know what engine you have, but I am confident that you do.)Install the chain (hopefully a new one), the side with the tensioner will be your slack side.Hopefully you used assembly lube when installing the cams, rotate the engine manually for a full 360* .Check your alignment marks. Dont worry about the colored links on the chain. (because of the slack side 99% of the time they will never match up.Assuming everything clocks out okay, spin the engine again 2-3 full revolutions to verify.If for some reason, the timing marks don't true up, reset the chain, and this time count links before and after rotating the engine. The FSM will give you # of links between certain points. Other than the wrong chain being used, the timing will always true up.
