Pop was $160. + shipping. The Z-tube was $60+ shipping.Hookm36 wrote:Beancook, where did you get the combo for 160.00 ? I want to get one, and I have a friend who just bought a G, so Im talking him into getting one also.
So after having it installed, do you just see the pop charger as something that effects the sound rather than performance ?
and on your rating of a 60, is that based on performance, if so w/out performance what would you rate it ?
Thanks for your help
Yes, you were right.joe603 wrote:Told ya you would like it!!!
Uh oh. I guess that is why I can never keep a girlfriend.beancooker wrote:Treat the MAF assembly as if it were a vagina. Be soft and gentle with it.
Do you have a pic of your's?rmezz13 wrote:When i bought my Z it had the pop-charger on it w/ heat shield, i didn't like the dull look of the heat shield so i polished it, turned out great, it looks so good i left it on even with the injen CAI. May serve a purpose in keeping the air cooler on its journey to the motor. My plenum stays cool to the touch until the motor heat warms it after sitting shut off but i also have a composite plastic plenum (Kinetix V+). Try the polish, and put a little d*ck into it when your polishing it, it will turn out nicely.
Just go with the Pop Charger for $110 and the polished tube for $97. Don't forget to get a bottle of oil for when you need to re-oil.all G’d up wrote:I think I'm gonna go with the JWT Pop Charger for my G. Is it possible to buy just the Pop Charger and then get the polished Z tube so it has a better look under the hood? I see them on Everything G35. The JWT kit is $195, the Pop Charger is $110 & the polished Z tube is $97. Can I use this combo or is there gonna be something missing that the kit has?
http://www.g35parts.com/9083/o...58_21
CRAMPIN MY DISPLAY NAMEall G’d up wrote:Ok thanks. I figured it would work together.
How necessary is the oil? Does the filter have to be oiled?
Yes, it has to be re-oiled when you wash it. It will come from the factory pre-oiled.all G’d up wrote:Ok thanks. I figured it would work together.
