so i have a suspension question :)
dsastr_clan
Car: 240sx
so since ive got my s13( it was fully stock) about 4 years ago i have always heard this popping noise coming from the front suspension area, it drives me nuts!! i though the issue was the shocks so i replaced them with coil overs, it didnt fix it so then i pretty much have worked replaced and upgRADE almost whole front suspension set up wanting to desperatly figure thi s*** up lol i havent been lucky at all, im about to get a power brace for it see if it works ( i dont know anymore its driving me crazy!!) pretty much every week i get under the car inspect eveything i make sure that nothing is loose and in order, everything seems to be fine. My friend is also experiencing the same symptoms on his s13, this popping noise happens when i reverse or when i do a U turn or a slow turn. When it pops the car jerks a bit toward the direction im turnin. Does anybody know what to do on this???
locoluna825
Car: 90 240sx coupe
change ALL your front bushings yet?
Dire91
Car: 1997 Nissan 240sx SE
locoluna825 wrote:change ALL your front bushings yet?
That's probably it ^
locoluna825
Car: 90 240sx coupe
UNLESS SITS YOUR RACK IN PINION. but then that wouldn't explain why it does it in reverse. soooo bushings?
dsastr_clan
Car: 240sx
Dire91 wrote:That's probably it ^
i have replaced my sway bar link and sway bar bushing with energy bushings, also i have replace the ball joints with regular OEM ones upgraded the tension rods to pillow bearing ones, also pillwow bearing tie rod ends with new tie rods. could it be the ball joints? they prob bad again? or is there another bushin around there i havent gotten to ? lol
dsastr_clan
Car: 240sx
i was thinkin maybe rack and pinion, but it works great!! i havent replace the rack and pinios bushings tho
White Comet
Car: fc, s13 and mazda6, Sierra
ball joint
dsastr_clan
Car: 240sx
oh snap! ill give it a shot ill let u guys know!
dsastr_clan
Car: 240sx
hello guys!!! so i have change by lower control arms and also the ball joints with brand new fresh ones!! now i gave it a test and my car still making that popping noise when i steer or intend to steer!! has anybody experience this?
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
what you could do is put the car on a rack and shake around all the suspension and steering components for play to see if you can hear the knocking. you have to do this with load, meaning car's weight is fully seated, and with no load.
dsastr_clan
Car: 240sx
yes, i have done that a couple of times actually everything seems to be tight and just to make sure i even try to get it tighter i have checked: coilovers. spring, ball joints, lower control arms, sway bar, sway links, inner and outer tie rods, front tension rods and front bracket support. Am i missing something??? anything? it pops pops and pops grrrrrr
nifares240
probably its your pillow ball bearing on the coils. since you said only on turns. have you tried to torque the lightly with an electric gun. just 2-3 quick soft burst will seat them fully. other than that, someone has to diagnose your car in person. typing the symptoms alone doesn't necessarily help.
dsastr_clan
Car: 240sx
could be but i hear the poppin noise coming from under, i will def try to tight the pillow bearing with the impact wrench, i was think maybe motor mounts will make the car make that noise?
kouki munster
Car: 97 base 240
Also check your steering rack bushings.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
nifares240 wrote:probably its your pillow ball bearing on the coils. since you said only on turns. have you tried to torque the lightly with an electric gun. just 2-3 quick soft burst will seat them fully. other than that, someone has to diagnose your car in person. typing the symptoms alone doesn't necessarily help.
Torque it to manufacturers spec.
Modified by OM3GA at 12:29 PM 12/24/2009
ag240
Car: 1993 Hatch, 1989 Hatch SE, 2010 Fronty SE
kouki munster wrote:Also check your steering rack bushings.
http://www.frsport.com/FRS-Alu....html Yes?
kouki munster
Car: 97 base 240
I was talking about the bushings that go in the mounts that hold the rack to the car. That was the first thing that came to mind when he said that his car would jerk towards the direction he is turning. If the bushuings are worn/missing the rack will shift and caust the car to jerk in one direction or the other depending on which way it shifts.
dsastr_clan
Car: 240sx
i just ordered a set of energy steering rack bushings, i will probable get them this week, and i will installed them this Saturday i will let u guys know if this fixes the problem
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
White Comet wrote:ball joint
I agree
dsastr_clan
Car: 240sx
thats what i thought, thats why i just replaced the lower control arms with new ball joints and that didnt fix it
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Sway bar bushings and end links? Tierods? Tension rods? Bent strut?
