ono wrote:i have 0 compression in all 4 cylinders in my 92 vert, ka24de but im stumpped
i highly doubt i blew all 4 rings....
my timing seems to be correct at tdc but i could be wrong
the only three things i can think of are blown rings, bent valves, or complete bs timing
any ideas guys? its a 120,xxx motor... auto... and a dual cam, i mean, what couldve possibly gone wrong with it?
thanks,Garrett
could only be 1 of 3 things....timings off..if this is the case and you tryed to start the car..then you bent the valves as well...#2 ..bent valves or ovaled out valve seats...#3....ring and piston issue..
with this type of problem..there is only one real option to rule out or fix any damage that may have occured..a full teardown of the motor....you may have to redo the head and or replace pistons...when you impact the valves with the pistons..something has to give...in a stock motor..i would be both piston and valves and possibly even impacting the piston with enough force to destroy the ring lands on the piston its self....take this good advice..and rebuild it..just to be on the safe side...good luck..what ever you decide to do.
