david gussie »
https://forums.nicoclub.com/david-gussie-u55820.html
Sun Apr 29, 2007 1:55 am
1. Your wasting your money! Full Synthetic can easily go 10,000 miles per oil change with a good filter.2. It must say All, full , etc. Synthetic. Some are Blends of 25% synthetic and regular oil. Cheaper too. I read from a news paper mechanic that a 1 to 5 ratio of synthetic and regular oil will give you all the benefit of full Synthetic oil. That might be better for you if you change so often.
3. You original Manuel will spec out what you were to use. The lower the first number is, the lighter the oil is at start up. For winter a 5-30w for your car is fine and a good all around one too. But it probably was speced for 10-30w for all around use. The lower the weight the easier to start and an initial small savings on gas milage. As a car gets higher milage on it and the parts wear, you can go up a 5 or 10 weight usually over 100,000 miles on the odometer,( that’s why u see 15-50 w oil. But if you change oil that often I would not bother.
4. A car wears out internally, most at start up without the car being properly oiled, not while its running. Fast cold starts in winter with out waiting (one minute only) to get oil pressure up is a killer. Also let the transmission go into reverse twice and once in 1, 2 ,D. This will circulate the fluids better. That is suppose to help. I have been told that. Do I do it, NO. My cars go 175 to 250,000. So I don’t worry about it too much.
5. The research data I read said that (most applications-useage) Full Synthetic oil went bad for most car owners around 14,000 miles and when they changed it they got a 10% increase in fuel milage. Therefore, for most applications an 10,000 mile oil change is fine. The oil is good but the cleaning additives are worn out or used up. Oil is oil and could be heated up to a high heat, burning off the impurities and used again. They did that in wwII to save resources and they pick up oil now to make it into grease Hope this helps
