180weaver »
https://forums.nicoclub.com/180weaver-u54414.html
Sat Feb 07, 2009 9:57 pm
take a lot of pictures, before and during. Get the manual like everyone else says and a torque wrench. if your not going performance buy the oem head gasket set and head bolts, follow the pattern, i believe its 4 steps. tighten once in order again to like 60ft pounds, loosen completely in reverse and do again. Make sure that the block isn't cracked anywhere find a good staight edge and a set of gauges to see if its square/warped and have the head checked as well. good luck
