Yeah.....I got some (uninstalled) 256 poncams with tomei gears....and I'm almost worried about accidentally setting the gears wrong and making less power than using the cams with stock gears.ks13 wrote:those cams are a paired set I believe and need no cam gears to optimize the valve opening and closing events, so I dont think Id be looking at degreeing the cams.
is it an 8 port or 4 port setup, and are the butterfiles working i.e. opening?
I agree with you on this one as well.ks13 wrote:those cams are a paired set I believe and need no cam gears to optimize the valve opening and closing events, so I dont think Id be looking at degreeing the cams.
Your best bet is to goto http://www.sxoc.com and ask around with regards to cam gears and timing with the 270's, or...have your tuner fiddle around with the gears and test out a few degrees in each direction.TopGunn wrote:Motors from Japan, its an 8 port head. Butterflies work you can see the rod open them when you hit the gas.
Running 91, it was having no detonation or knock on the high boost?
Im really starting to think my cams aren't dialed in, but I need the specs on the cams and I can't find them...
Upon searching google for "T67" I'm finding its a popular choice for the last gen supras...which.....means it is waaaaaay too big for the CA. Sell that thing on ebay and get something that will actually spool on your motor.Buddyworm wrote:I think you need a smaller turbo Dan. The greddy T67 uses a 25G wheel. Which is huge. The CA just isn't big enough to use the compressor at its peak efficiency, which is why I think your power numbers suck even with so much boost. Even though the 25G wheel is moving a lot of volume you're not getting it anywhere near its sweet spot so it's not compressing the air efficiently and you wind up with inferior charge density.
I can't find a compressor map for a 25G but even the smaller 20G wheel, while a better fit, is still too big unless you're revving the engine to 9000rpm.
That's all bench racing though. Let's see the dyno plot.
Right idea, wrong explanation, sorta. I'd wager that theoretical 25psi is just running the turbo past, or too near its choke line or the specified boost just pushes the turbo up to an innefficient point of its range.KEMP wrote:technically if the turbo is "too big" on say 25psi, then theoretically, turning th boost down to say 15psi, would weild more power by achieving set boost quicker and holding that boost setting well in the spool of its effiecency range.
if the turbo is too bg and thats why the car made unacceptable power, then turn the boost down, and it should make the same/more power by holding a lower boost quicker and longer throught the powerband and the set boost efficenecy...this is a theory that lotd and lot of honda guys have thought and some have been proved to be correct, food for thought, not stating its a fact.
