you should be able to tyten the 10mm bolt on the brake cable....saw a thread earlier talking about this........ he was talking about makin ur own e brake cover but he said if it goes up too high you shoud be able to adjust it to where ever u want it to by that 10 bolt.
"In the up position. NOTE if you have to pull your E-brake boot all the way up, and into the back seat to get it to engage, look at the front of the e brake while the cover is off, there a little 10MM nut in there that you can adjust the cable, to tighten it up, simply tighten the bolt down, you can set it how you like it, I like mine to only come up about 7 inches from the center council. "as sed by vroom-chirp
zerothread/237484
but ur brakes do work though right?
Modified by addisonblck at 7:57 AM 3/8/2008
