av8or wrote:did you have to replace your studs when you added 20mm spacers? thinking of adding to my stock for a little agressive look... what is the biggest i could get without replacing my studs, both front and rear...?
I bought hub-centric spacers that have pressed in studs. Therefor, replacing my studs was not necessary.
As far as installing the simple plate spacers, I wouldn't recommend installing any, without going with longer studs. The rule of thumb with installing spacers is that you want the lug nut to thread onto the stud as much as the stud is thick. So, we have 12mm studs. With a thread pitch of 1.25mm, that means we need to thread the lug nuts on at least 9.6 full 360degree turns. From what I recall with my OE 18" wheels, that's about what they're threaded on WITHOUT a spacer. So, if you went with even a small 5mm spacer, you'd only get 5.6 turns. NOT STRONG ENOUGH.
So, get the bolt on kind or install longer studs.
-Jerome
