so I dont think I have ever heard of a vac issue like this
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
finally ready to fire up the motor and it will run...... here is the conditions.
maf plugged in- no go
maf unplugged no break booster- 22HG and is superb idle at 850. all vac created at the break booster from what I can tell?
break booster plugged/ hooked up and no maf- no go
wtf did we do wrong?
Im getting plenty of fuel and when it does run it seems to be running properly. It has to be getting fuel and spark........ timing belt was changed, but it fires right up with the break boosted unhooked and no maf.
what havent I though of. I know we redid a ton of vac lines.........
Im very confused.
riken1337
Car: 90 s13 CA18
Is the check valve to the Brake booster on backwards? That's the only thing I can really think of. Or a leak in the Brake booster
Modified by riken1337 at 10:16 AM 4/27/2009
bradt
Car: 1989 240SX CA18DET
BRAKE booster. Sorry, that was bothering me.
However, I concur, check it out gabby
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
check valve def comes to mind.
ca18detgabby
03 Infiniti G35
pretty sure my timing is funked up.
any manifold vac line pulled and the car idles like a champ......
played with the CAS a bit and it ran a bit better fully retarded.....
must be off a tooth or two
float_6969
I was just going to tell you to triple check the timing and have every neighbor on the block look at it too.
I can't tell you how many times I have SWORN I had the timing right and I was off a tooth.
ca18detgabby
03 Infiniti G35
float_6969 wrote:I was just going to tell you to triple check the timing and have every neighbor on the block look at it too.
I hate doing timing....... it sucks.......
bradt
^TRUTH
