So I decided to do something about the weak stock brakes...
Ghost_silvia
Car: 1991 nissan silvia s13
So my girlfriend was complaining about how her 240's brakes fade and made noise so I took it into my own hands to fix that little problem. Hence the pics. Needless to say we're both satisfied with the outcome. The braking is very noticeable when slowing from higher speeds. Now if I can only get her to complain about the ride height, so I can give her my tein basics and buy some stance coils.
Modified by Ghost_silvia at 2:18 PM 11/16/2009
MastaYu
Car: 92 Nissan 240SX SE HB
very nice!!
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
sweet i need some 350z calipers...what brackets did you use to make them work?
roadboy240sx
Car: I like Nissans
splintercell wrote:sweet i need some 350z calipers...what brackets did you use to make them work?
+1
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
Sick man. +2 on the asking what bracket to use lol.
Deep inside I want alum 4pist calipers up front, but my J30's are fine for now :/ lol
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
Didderson wrote:Sick man. +2 on the asking what bracket to use lol.
talk to me, goose. you KNOW i want an excuse for bigger front brakes...
splintercell
I have the R1 WURKS aluminum caliper adapters to run 350z rotors using 300zx calipers. i assume the Brembo's would mate the same way.
adrianfromthecastle
Car: 1992 Nissan 240sx
brake (noun): a device for slowing or stopping a vehicle or other moving mechanism by the absorption or transfer of the energy of momentum, usually by means of friction.break (verb): to smash, split, or divide into parts violently; reduce to pieces or fragments
/grammar lesson LOL
anyways, back to the topic.... they look great!
what are you doing for the rears?
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Ghost_silvia wrote: Now if I can only get her to complain about the ride height, so I can give her my tein basics and buy some stance coils.
lol. What happen when she complains about power?
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
splintercell wrote:I have the R1 WURKS aluminum caliper adapters to run 350z rotors using 300zx calipers. i assume the Brembo's would mate the same way.
i don't quite understand the purpose of using z33 track rotors with z32 brakes. you're getting less use of the pads' surface area, and even if you did use the full pads, you still aren't using the rotor 100%.
adrianfromthecastle
more rotor surface area (by circumference) = less heat
at least that's what I'm thinking
numbnuts240
2011 Ford Focus
2010 Mazda 3
breadbox wrote:lol. What happen when she complains about power?
she calls me.
adrians_s13 wrote:more rotor surface area (by circumference) = less heat
while that may be physically true, i really don't believe that 99% of people who do this are really benefiting from this. almost like it's just bragging rights at that point.
splintercell
i know this, but i won the bid dirt cheap and i didnt want puny little rotors behind my 17" enkeis...these look a whole lot better, but i dont track my car so i could care less...car still stops on a dime.
numbnuts240
2011 Ford Focus
2010 Mazda 3
adrianfromthecastle
numbnuts240 wrote:while that may be physically true, i really don't believe that 99% of people who do this are really benefiting from this. almost like it's just bragging rights at that point.
LOL.. true. Probably the same reason why people get Endless 12pot pistons for HIN.
but just like how wheel gaps are considered ugly, so are small brakes on huge rims
Ghost_silvia
Actually they're not 350z calipers they're sentra calipers. But I believe they use the same pads, so in turn would have the same braking surface as 350z calipers. If she wanted to do anything else to her car I would probably swap stuff from my car and buy new stuff for mine.
Ghost_silvia
Sentra calipers bolt right up and I used Ser Spec V rotors w/nissan spec V oem brake lines. The back I might just throw some slotted rotors with hawk pads when I get some cash or pay off my credit card. The only reason I went with this setup was because I got one caliper off craigslist for $20. The other only cost $90 so $110 for two brembo calipers is a steal! The whole kit without spacers cause I have a high offset wheels, was under $300 (rotors,calipers pads included, extra line and misc.) Oh and before you go out and spend money on these make sure your wheel will allow these to fit. 17" but the wheel design, like my rota 962's wouldn't clear the caliper diameter wise.
Modified by Ghost_silvia at 2:32 PM 11/16/2009
