Thanks bud much appreciated. I did more research on the G35 VC's and they were in fact different in enough ways where I didn't want to mess with it. So I'm back to the whole drilling/tapping/aftermarket fitting idea. I dont mind doing that, I'm just trying to make sure I use either the right rubbber washers to ensure it fitss snuggly or somehow in some other way to ensure its air tight. The other concern I have is making sure I get the right type of fitting, you said brass so I'll look into it, but if this stuff is anything like plumbing I gotta be careful as to what I use since the VC's are plastic, I need something that will work with it. I dont want aluminum or something else not working well due to expansion and contraction under hot/cold. I dont know really what would be best but I need to look into it.
Open to suggestions if anyone's got any. I'm considering something like this...
https://www.summitracing.com/parts/ear- ... /overview/
